I decided to take No 42 for a leg stretch, as I am back at work soon and the wx is bound to be 'orrible week after next.
A blast out to Chippenham and the lanes back to home. Anyone who says an XI is impractical clearly hasn't seen one with guttering strapped into the pax seat with a four-point harness.
When I got back, I noticed a nearside rattle. My silencer has worked loose (probably lost the exhaust clamp during the caning!). Probably a good opportunity to whip it off and see about getting hold of one of the metal, noise-reduction cones mentioned in the other lists.
I'm still working through what I think is an oil control problem. Initial compression test with Mike's Dad-In-Law's vintage compression tester showed 150PSI, but it doesn't hold the pressure for analysis. So, I have a modern, conventional item coming next week. If the valve stem oil seals have become brittle with age, or aren't a great fit, then the compression test will always be "wet" and that isn't helpful for diagnosis. Everything looks good under the rocker cover, and I was going to check the valve clearances anyway.
These trivial matters aside, it's an occasion every time I get into this car . I can't think of any motor I've owned or driven that has given me so much pleasure!!
Hurrah!
