Hi,
A very basic question for those in the know!
My timing cover had a TDC mark painted onto it which bizzarely disappeared when I stripped all the paint off (...!).
There aren't any physical timing marks on it at all now, with only the single mark on the crank pulley.
Is this going to prevent me from setting the distributor timing or is there a work around?
Many thanks.
Morris.
Timing cover
Re: Timing cover
the loss of your timing marks shouldn't be a big problem for you. it's straightforward to find TDC through the spark plug hole of number 1 cylinder and then you can make new marks to either align with the existing crank pulley one or somewhere new on the pulley/engine thats easier to find
I personally use a long narrow bladed screwdriver down the plughole to rest on the piston and turn the engine by hand and watch the screwdriver rise and fall to try and get the centre of the max lift of the piston ( make sure the cylinder is on the compression stroke)
My way isn't the best way but it's what I do, but do be careful not to drop anything into the cylinder! I am sure google will bring up many alternative methods.
once you have TDC you can put any other marks on the pulley by measuring it's diameter and a bit of maths or if you have the right timing light you will only need TDC
BTW my timing marks are pointers on the underside of the engine not markings on the timing cover, I am sure you've looked but just in case
cheers
cheers
Re: Timing cover
Many thanks, that's a big relief.
Btw I didn't realize there may be timing marks on the underside of the engine, although during its rebuild I didn't notice any markings.
This may be the final hurdle before sending it to the Dyno!
Morris.
Morris.
Re: Timing cover
if you do a search on google images I am sure you'll find a better image of the timing markers I have on my engine but here is a link to one of them that has a couple of drawings
https://www.mgexp.com/phile/3/197903/Mi ... _marks.jpg
Re: Timing cover
Hi All,
Hope you’re all safe and well.
My engine had no timing marks. At Slark’s, Neil used a dial gauge with extension to accurately find TDC. He then re-marked.
If you can mark TDC, and set the static timing, then using a Dial-Back strobe will sort your timing right out. Something like the Accuspark SP8000.
If the car runs ok, then I guess all this could be done on the dyno.
Good luck! Glad to see some XI progress being made. Mine is still SORNed and garaged, with another car stuck in front of it for the time being.
