Distributor Rotors
Posted: Wed Jun 08, 2016 4:40 pm
Preamble.....
At a track day last year my car developed a slight misfire. I tried driving through it, but it seemed to become worse. "Not to worry," thought I, as it was at Thruxton (my local circuit), I'd brought the Gallardo along too and rain was threatening. Once cool, the misfire evaporated and I was able to drive home without mishap. I checked what I could and could find nothing amiss.
I undertook several longish drives after that (and quite a few short ones out to Thruxton where we keep our Chipmunk) with no further reoccurrence. But then, on the first drive of this summer, after half an hour of driving I stopped at a local pub for a half in the sunshine and when I started back up again I had a serious misfire. I was only a couple of miles from home, so attempted the drive. I conked out a few hundred yards later, but after a few minutes of cooling I was able to restart and drive (noisily) home. When I came to investigate later, the misfire had disappeared and I could find nothing wrong. At Jan's suggestion I checked my alternator output and found it to be about 19v, but this proved to be my ancient, cheap analog meter (discovered when my replacement alternator also appeared to be producing 19v!!).
About a week later I attempted a further drive. After about fifteen minutes a misfire developed and rapidly became worse. I set about returning home but after a few more minutes the engine died in the middle of nowhere (well OK, a country lane near Highclere). It was obviously not going to restart, so I called the RAC and waited. Shortly before their chap arrived the local farmer/land-owner pulled out of his driveway a couple of hundred yards away and drove over to me. As all Hampshire farmers are wont to do, he showed me photos of his race-prepared Europa twin-cam and his wife's Bristol-engined Ace and we chatted until the orange van was on scene. Courtesy of a pair of well insulated pliers we soon discovered that there was HT from the King lead but not from the plug leads, suggesting that the rotor arm had failed....
I run an Aldon distributor with one of their Hall effect electronic ignition sets (actually a Pertronix unit, I believe). This is based on the Lucas 45D distributor. The RAC man just happened to have a rotor arm for a 25D in his van (commonplace twenty years ago; a minor miracle today!) which got me home. I posted it back to him the following day.
My new friend the farmer, recommended that I look up the "Distributor Doctor" as a source for a new rotor. Whilst on his site I came across an article that perfectly describes the failure mode that I experienced and explains the cause (do read this, it's short but enlightening!):
http://www.distributordoctor.com/rotor_arms.html
I was actually aware of the problems of the modern "Lucas" rotors. (FWIW, Lucas make NO parts for older vehicles. It's all manufactured in the Far East and distributed by Lucas in their green boxes.) Therefore I had deliberately sourced a Bosche rotor arm, which are still made in Germany. But this had failed in exactly the same manor as the pattern Lucas part does.
So I'm now running a DD rotor and everything seems good. It seems to be yet another example of the folly of using pattern parts. I bought two of his rotors together with a NOS Lucas rotor from eBay, all being about the same price as a pattern rotor.
The difference in quality is quite clear to see from the following photos. Here are pattern Lucas (black thermoplastic with the offending rivet), brown Bosche (also riveted), black NOS Lucas (thermoset, no rivet, Lucas script and crest moulded on) and Distributor Doctor (red). Note the difference in both the thickness of the insulating material and of the brass contact on the latter two when compared to the modern replacements:
