Time for a quick update, as this little mod is yet to be installed.  I've been swanning around on my hols, y'see?
I have received my 1/2" hose, GRH510 bottom hose and new jubilee clips.
The main point to note with GRH510 is that the spigot is mounded to the outside of the main bend.  As water flows down the radiator and up the engine, I want to plumb into the radiator return, just downstream of the thermostat.  This will slightly slow the engine warm up time, I guess, but promote slightly cooler running in my set up.
A quick ratchet around in my gasket collection turned up a fresh heater tap gasket.  I'll spin the tap to point nearside, and run the hose on the hot side of the engine. Some new, stainless and rubber, 20mm P Clips will hold the hose away from the manifolds and run it down to join the GRH510.  Finally, a brass 1/2" joiner will complete the job.
All in theory!  I'll post some pics when the job is done this week...
